58b not emailing
Hello, thanks for the all the work you have done! I am having a problem with TTD not emailing. Here is a copy of the debug for 58b. Any help would be greatly appreciated. Thank you!
Succesfully retrieved local tone info
Tone1
704.0 Atone1
704.0Atone2
A Tone Found! 10:10:38
1359303038.18
Checking for B Tone 10:10:38
2.8 10:10:41
1359303041.16
done sleeping at 10:10:43
1359303043.75
pre-record
1359303043.76
post-record
1359303043.94
Checking for B Tone2 10:10:43
1359303043.94
747.0
Tone Set Found! 10:10:43
1359303043.94
ValleyMills[4] 10:10:43
******@*****.org,*****@*****.org
delay timer ValleyMills[4] 10:10:43
waiting for audio ValleyMills[4] 10:10:50
recording audio ValleyMills[4] 10:10:50
done writing WAV ValleyMills[4] 10:11:18
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[wav @ 00398880] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 00398880] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/ValleyMills[4]_2013-01-2710_11_18_053000.wav':
Duration: 00:00:27.86, bitrate: 176 kb/s
Stream #0.0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 1 channels,
s16, 176 kb/s
[mp3 @ 030AC960] Unsupported sample rate.
Output #0, mp3, to './audio/ValleyMills[4]_2013-01-2710_11_18_053000.mp3':
Metadata:
TSSE : Lavf53.12.0
Stream #0.0: Audio: mp3, 11025 Hz, 1 channels, s16, 24 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 82kB time=00:00:28.00 bitrate= 24.0kbits/s
video:0kB audio:82kB global headers:0kB muxing overhead 0.039281%
done converting to MP3 ValleyMills[4] 10:11:18
Traceback (most recent call last):
File "<string>", line 447, in mail
File "C:\Users\Deer Creek Fire Dept\Documents\Python\build\pyi.win32\TwoToneDe
tect58b_debug\outPYZ1.pyz/smtplib", line 242, in __init__
error: [Errno 10013] An attempt was made to access a socket in a way forbidden b
y its access permissions
[wav @ 00288920] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 00288920] max_analyze_duration 5000000 reached at 5015510
s16, 176 kb/s
Output #0, amr, to './audio/ValleyMills[4]_2013-01-2710_11_18_053000.amr':
Metadata:
encoder : Lavf53.12.0
Stream #0.0: Audio: amr_nb, 8000 Hz, 1 channels, s16, 10 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libopencore_amrnb)
size= 37kB time=00:00:27.88 bitrate= 10.8kbits/s
video:0kB audio:37kB global headers:0kB muxing overhead 0.015941%
done converting to AMR ValleyMills[4] 10:11:20
699.0 Atone1
618.0Atone2
