I'm a complete beginner so please excuse some dumb questions. As will be obvious, I'm a bit confused.
I bought a couple of these active whip antenna kits (see photo) to try them out on an RTL-SDR Blog v3 dongle. Each one came with a separate module - one labelled "Low Noise Amplifier" and the other, "Bias-T".
I know that both modules are designed to supply DC to the active antenna component via the coax but
a) are they otherwise the same thing and can they be used interchangeably with either antenna?
b) if the modules are meant to do different things, can/should they be used together on the same antenna and if so, how connected?
