I know this is a little bit of an old thread, just looking to see if anyone has some updates, or advice now that the systems have been out a little longer.
I'm looking to lease space on a wide area network for a small property management operations team. I have the options of going with a Nexedge system (OnQue), or with 2 different Mototrbo systems (GoTrbo, or Turbo-Connect. Operated by two different companies.) I'm hoping someone has some experience on these networks that they can share, or let me know if I'm really going to notice a difference from one to the other.
Just as some additional information. Both are similarly priced, and have coverage in the same area for me. The OnQue system has a better sign on promotion currently, but the turbo-connect offers more coverage included in the base monthly charge.
Hope someone can help me out with some advice, thanks in advance.
I have also used both. I am not sure what it is, I just don't trust the mototrbo equipment. I have tried vertex standard also and have had brand new units fail at 5 days old. Granted you don't get a 2:1 repeater with nexedge but I have never had a failure with nexedge or icom Idas. I truly trust that equipment.
Has anyone had a chance to use the NX 5X00 series? Or heard from anyone who has used them?
I remember someone saying DMR was actually more spectrally efficient due to a small buffer needed between two adjacent NextEdge channels but I'm not sure I buy that.
Not that long ago, the FCC released a report and order on allowing "non-standard pairs." That's a terrible misnomer that makes people think it's not a 5 MHz UHF pairing, but really, it allows for two 4K00 emissions to be placed 3.125 kHz removed from the center frequency of certain UHF channels, with the proviso that the center frequency also be licensed, and that the stations be licensed as FB8 (exclusive trunked), which is a disparity when compared to DMR. I've seen some of that implemented around Kentucky (but surprisingly not in many other areas).Yeah, if you look at the TDMA part of DMR, and being able to fit two time slots in to 12.5KHz of bandwidth it is more efficient than NXDN. Due to combiners, you'd need more space to get two NXDN channels in.
Flip side is that NXDN can run in true 6.25KHz mode, while DMR can only do "6.25" equivalent, or putting two traffic channels into 12.5.
In reality it usually isn't necessary to need channels so closely spaced together. I have 5 800MHz pairs separated by 500KHz, each. Not a problem with modern transmit combiners. 800MHz spectrum isn't congested here, so no issues.
I could see in some instances where two slot TDMA would be a huge advantage, though. Just not in my situation.
From my vantage point, narrow NXDN's chief utility is in urban areas where an agency "has to" have a VHF frequency pair. Given the TSB-88.1 D relationships, and the corresponding LMR adjacent channel deratings, it's possible to squeeze on into frequencies where wider signals, like DMR would fail adjacency criteria. Same can be said for UHF. There are quite a few places who are dunking for frequencies at the bottom of the license barrel. The narrower they are, the better the possibility they'll be able to find a suitable frequency.
The other issue with DMR is channel occupancy patterns. DMR usage can be pretty singular. Some public safety agencies had been on a frequency for decades coexisting with other agencies all over. Things were in balance. Then, during the height of the narrowbanding "crisis," they buy a DMR repeater and make 2 channels out of 1. Woot! However, the defaults on the repeaters have a long hang time. And, some systems are running AVL on timeslot 2. This could mean the repeater hangs on in transmit just about all day, almost like a trunked control channel. That creates a plateau of interference that weaker signals can't overcome. In a lot of cases, the repeater is on someone else's input frequency on VHF high band. Then it pretty much blocks anything beneath it, and possibly superimposes digital artifact onto a stronger signal (think heterodyne, except one of the components is the DMR station). So, practices for TDMA (because no one's picking on DMR, it's really ANY TDMA implementation on shared use frequencies) require having below a certain threshold value of signal at the receiving stations' antenna, at the same height as the antenna - not to mobiles (the way coordination is usually done).
That's not a problem in paired environments, like UHF, where the transmitter to receiver separation will always be 5 MHz and outputs will not fall on inputs.
Two narrow NXDN channels fit nicely in 12.5 kHz and provide the exact same capacity (9600 bps, two voice/data paths) as one DMR channel, so where is this extra efficiency?Yeah, if you look at the TDMA part of DMR, and being able to fit two time slots in to 12.5KHz of bandwidth it is more efficient than NXDN. Due to combiners, you'd need more space to get two NXDN channels in.
With NXDN you will need two repeaters, plus associated duplexer/combiner equipment for two voice paths, where as with DMR you only need one repeater and one duplexer for that same two voice paths. You are talking thousands of dollars difference in cost for the same two talk paths.
That has nothing to do with spectrum efficiency. And it ignores the cost of the dozens, hundreds or thousands of subscriber units the system supports.With NXDN you will need two repeaters, plus associated duplexer/combiner equipment for two voice paths, where as with DMR you only need one repeater and one duplexer for that same two voice paths. You are talking thousands of dollars difference in cost for the same two talk paths.
This NexEdge system and its subscriber units have no issues with 6.25 kHz channel spacing. Nor does my cheap netbook with its $10 DVB-T dongles; four carriers side by side in this screenshot and no decoding errors or audio distortion. I have no specific info on what hardware this airtime provider is using, but it obviously works just fine.Because of the TDM, you get the two timeslots to use in 12.5.
I've heard some Icom's will do two 6.25 channels right up against each other, but the Kenwood's won't. You'd need a bit of separation to make the combiners work right.
I've only got a NexEdge trunked system, so I don't have any real experience with the Icom iDAS version. I understand there are variations, but I'm looking at just the NexEdge/Kenwood versions.
