NJSP help
k2sg
Brooksville, FL
I have been away from monitoring for some time and trying to get the NJSP setup again on my new PSR600. I noticed conflicting information depending on what source I looked at. I also noticed the note in the RR database section that the NJSP system is in transition. I had planned on setting up three seperate lists, one for each Troop such as I have done in the past using banks because that's what I'm most familiar with. Are the current RR listings for Talk Groups and frequencies up to date? I found several differences comparing John Burricelli's KC2KZZ "New Jersey State Scanner Guide" dated 3/4/2010 to the RR database and wondered which one is most accurate. Any guidance would be appreciated. Tony K2SG
Danny6569
Riverside new jersey
State police
They should be pretty much done now with there transitions, they were doing some changes a little while back but everything should be up to date now.
W2SJW
Senior Member
Northwest NJ
I was the one that did the major upgrade to the NJSP in the database. My data was a correlation of John's & a number of other reputable sources. What you see their for the majority of the critical system users is spot-on...
k2sg
Brooksville, FL
Scott & Daniel, thank you both for your helpful information. In the past I have always found the RR database fairly up to date but the Red notice on the NJSP that the system was in transition really got my attention.
Thanks again!
..Tony
