So my 20+ year old Larsen NMO-2/70 dual band antenna finally bit the bullet.
I've always had several vehicles and I've moved the antenna back and forth between them quite often. I also remove and replace it whenever I'm parked for longer periods in pubilc areas to prevent theft. Over time the spring contact in the middle lost a lot of its 'springiness' and wasn't making a good contact with the center pin on the mount'. I took to bending it out with my fingernail before I installed the antenna so there would be a better contact.
Well.. Bend a piece of metal back and forth long enough and it will eventually break. And, after long faithful service, mine did. I notice the gasket has perished as well. I was thinking of soldering the broken tab back on, but that's only a stopgap fix. Time for a new coil. Just wondering if anyone else has had this happen to them?
