No audio
wiliki46
While receiving the antenna icon shows up on my 700P but there is no audio. What is happening?
Radioman96p71
Do you hear tones when pressing buttons? Does the volume go up and down on the display when you turn the knob? Does it make any noise at all? If no, then its probably the speaker, the connection to the speaker in the case or it could be a problem with the audio PA.
If some things make noise but still no voice audio it could be a programming issue or perhaps something with that system.
Was this a sudden occurrence or has it been like this for some time?
wiliki46
I know the volume knob is actually broken. I have the radio set to minimum 20 in the personality. It happened after rebanding about a year ago. It is like the radio is not decoding some of the channels. It is like having missing channels but I have them all. It does not happen on all of the sites.
HarrisRF
Lancaster, Pa
Is this conventional, or trunked?
it only happens on certain systems or channels?
when you press any button does the radio go "beep" or "boop"?? LOL
If conventional, do you see a CG indicator? when you are recieving with no audio press and hold the CLR/MTR button(little button on side above PTT). After a second or two do you now have audio?
if trunked does the audio go away after every X amount of PTTs then the next PTT has audio?
wiliki46
It is a trunked system. I listen only. The buttons make a sound when I press them.
HarrisRF
Lancaster, Pa
then youre speaker is good. You get an antenna symbol which means you are recieving.
Is this provoice or or in the clear?
When the antenna symbol comes up, and you press the CLR/MONITOR button do you hear digital junk almost like the CC data, or do you hear the TX voice?
you say its been going on since rebanding. is it your radio only, or all 700ps? 800mhz i presume? or did you go narrowband recently on 450?
Your probably going to need to have the radios software recovered and tracking data tuned. If its specific to your radio then its not a major issue. If it happens to all radios intermittantly you may have station problems which is quite major.
wiliki46
It is a provoice system. I have tried pucshing on the CLR/MONITOR button and hear nothing. It happens to my radio and another LPE200. It is on 800mhz.
