BCD325P2/BCD996P2: No longer decodes DMR
Pr999
WRYF747
Plainwell, Michigan
My 325 seems to have stopped decoding DMR for whatever reason. I'm trying to listen to the school busses in my town and can't pick them up, I can get show and lock on to the signal but it will not decode it or any for that matter. Ik they haven't gone encrypted because it would show otherwise and I could hear it, It's not like P25 Phase 1 ENC. To add; I did a test between my TRX1 and my 325, the TRX1 received it just fine but the 325 didn't even peep, so it's not the reception.
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
Is this conventional DMR or a trunked radio system? If the former, is (are) the channel(s) programmed conventionally or a part of a one-frequency trunked system? No channel(s) locked out?
Pr999
WRYF747
Plainwell, Michigan
Is this conventional DMR or a trunked radio system? If the former is (are) the channel(s) programmed conventionally or a part of a one-frequency trunked system? No channel(s) locked out?
Conventional. I also have it programmed as OFT. It used to work but now it's silent. I also forgot to mention I have the DMR upgrade too.
tvengr
Well Known Member
Baltimore County, MD
There is no way you can remove the upgrade once in the scanner. The scanner will not receive DMR at all without the upgrade. Did the color code, TGID, or slot change? Try putting the scanner in ID Search.
tvengr
Well Known Member
Is is safe to assume this is what you are trying to monitor?
Allegan Area Schools Consortium​
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
153.6875WRAA497RMCC 2
TG 1
SL 1
AAESA BusAAESA TransportationDMRSchools
bearcatrp
Land of 10,000 taxes
You verified the DMR upgrade still shows in the radio? Try this. Remove batteries, press power button for 5 seconds. Put batteries back in and see if that worked. This is similar to a pc to make it read the bios. What antenna are you using? The TRX using the same?
Pr999
WRYF747
Plainwell, Michigan
Yes, I have. Also what you told me to do didn't work. I'm using a remtronix 800 antenna. And no it's not. I usually have very good reception due to how close and powerful the repeater is.
bearcatrp
Send joebearcat a pm to see if he has any ideas. Sounds like you tried everything. Maybe go on the other side of town to see if you can pick up anything DMR.
