Thatsclear
- Joined
- Oct 25, 2019
- Messages
- 108
I was advised that some radios don't have the scan option because people were scanning and missing traffic on their assigned channel. Is this common?
Thank you
Thank you
Are you talking about two-way radios used by a company or agency?I was advised that some radios don't have the scan option because people were scanning and missing traffic on their assigned channel. Is this common?
Thank you
FWIW, I manage a small fleet of HTs (12 radios.) Since everyone using the radios isn't a comm person, I programmed the radios using the good old KISS principle. No scan, no monitor, nothing more than the basics. All they can do is to turn the radio on and off, adjust the volume, change the channels and push to talk / release to listen.
My thought process is the less they have, the less that can go wrong or get messed up!
Sometimes on/off/volume is difficult. ("I guess I had the volume turned down all the way and missed your call….") I often set minimum volume on radios, too. Make it so it cannot get 'accidentally' turned down all the way.
That's a great idea. I'll have to look into that.
The biggest problem I have had with radios is folks on the wrong channel, even though I tell them to do a radio check after they power up the radio.
I give a "Radio-101" presentation annually...
I give a radio use class and explain that if your sent to a channel stay there until told to change as this will be the channel for the situation at hand,
My county did that, a couple years ago. Those two TG are not monitored by dispatch centers, and every public safety agency has access to them.I heard a FF today calling in a mayday during a training drill, he was on dispatch. Someone told him he was on the wrong channel, next thing I heard he was on a multi county mutual aid channel. They chased him off there too, never heard any more, I don't scan training TGs.
I've often wondered why a complete zone wasn't dedicated to training so the channel selection process would be the same or very similar to real life.
