Retired auto mechanic new to scanners still learning by mistake which is expensive. Would like someone more knowledgeable to verify my diagnosis. This has been an issue for months.
Picking up noise (hum and what sounds like a really attenuated NOAA broadcast) when there is no traffic. I’m not sure if it NOAA but it is constant muted unintelligible talking.
Setup includes 50 feet of RG8x (#1 suspect), a Tram discone antenna, and a Home Patrol II. The XYL doesn’t like the ‘chatter’ so I bought wired headphones.
The RG8x coax connects to an air gap arrestor grounded to an 8 foot ground rod. The other end of the arrestor has a 1 foot RG8x jumper through the wall. A 6 foot PL259 to SMA cable connects to the scanner. All connections are tight.
Once in a while the noise stops for 1-2 seconds. If I disconnect the coax from the scanner, the noise stops. If I touch just the coax nut to the scanner connector (not threading it on) I can hear the noise.
If I use the antenna that came with the scanner there is no noise. If I disconnect the cable from the antenna outside and connect the antenna that came with the scanner there is no noise.
I heard the noise with my PRO2096 scanner also.
Before this 66 year old man with arthritis climbs on the roof again to replace the coax with something better, is my diagnosis a possibility?
Could the coax be the cause of the noise? I read that RG8x has a lot of loss.
The closest power line is over 100 feet away. There is nothing nearby like a transmitter. I can hear the noise any time day or night.
