North Hampton PD
NH
Does anyone know the PL codes for North Hampton's town channel. Fire and PD use the channel quite a bit but I cannot find any info on it. 156.225
ecps92
Taxachusetts
95% of NH uses 136.5 Hz, give that a try.
If it is, pls submit for inclussion in the RRDB
If not, most of the new scanners can SEARCH for the PL/DPL
NH
Well, RFWIZ.com has it under 136.5. My portable scanner doesn't always pick up that town from my house so it isn't going to be able to give me the solution. I drive through there with my truck and my Kenwood doesn't have that function. I'm going to cross my fingers that Rfwiz is correct when I get my DPLs put in. Right now this channel will idle like an open mic because something in my new truck triggers the Kenwood and the Pro-106 off. It never did that in my old truck.
ecps92
Taxachusetts
your TAG LINE indicates you have a Pro-106, use that to find the PL Tone :eek:
NH
I don't take my Pro-106 to work. I have it in the truck when I'm just driving around town. That's when it will trigger it off and open mic the two radios. North hampton is just a direct line. It is very weak picking up signal when I'm in their town. I briefly got something off my 106 last night around midnight when the airways were open but it didn't get the PL.
NH
I was able to code the channel tonight with my Pro-106. It's 136.5 as RFWIZ stated online. Someone wanted me to send it into the database here, how do I do that?
