NX-5000 Programming
radiomankc
Hello, I am new to the Kenwood KPG programming and have a simple question. I have analog, DMR and P25 channels to add. Is there a way to have these multiple protocols in a single Zone? If not, how do a create separate protocol zones? I've figured out how to set up a single profile but how do I add multiple profiles..i.e. One for analog, one for DMR and one for P25?
kd4efm
Florida
If you user personality tables. Otherwise no.
Go to product, open thar, and table type.
You can not flip back and forth, you have to have a separate code plug for the two types of formats.
Sent from my SM-G935P using Tapatalk
kd4efm
Florida
Keep in mind, right now there is no export function, so plan accordingly, don't download a 1000 things and then change your mind. Start small first.
radiomankc
Kenwood NX-5000 - NOAA
I have set up a NOAA ZONE/Channel group with all NOAA Freq. I just want it to alert on 1050Hz. Where do I set this in programming? I've set up an 1050Hz in it's separate bank but cannot get squelch to open only after 1050Hz.
kd4efm
Florida
Under 2 tone. Make it analog, not NXDN, and I believe you can set tone a and b blank.
radiomankc
I did under the 2 tone but cannot proper;y assign the silence until tone on the scanning bank.
radiomankc
To everyone's help here, I got everything working.! Except I have a NOAA bank wiith all noaa freq and have enabled the 1050Hz tone but I can get that bank silenced to only alert on 1050Hz. It scans and grabs the noaa freqs. I just want it silent until it tones 1050Hz.
ohiohonda
There are three things that have to be set for the radio to function that way. First you must set one of the decode two tone settings for the 1050HZ tone and duration. Second you must set the optional signaling on the channels that you want the two tone or work on. This is under the Channel Edit tab and labeled as optional signaling (analog). Third if you only want this channel to unmute when it receives the optional signaling you must set the audio control for qt / dqt and optional signaling. This setting would be under the system that the channels are assigned to, personal features, and under the analog section. I don't know how well this will work if you are trying to decode that 1050HZ tone while scanning. Depending on how many channels are in the scan back you could miss a portion of the tone and the radio would not unmute on that channel. Hope this helps.
