Nxdn info for Sumter, Dooly, and peach county.
Medic7046
Can anyone provide Nxdn system info for the above counties please?
Medic7046
I have. It has some but not all. I work Ems for a neighboring county to those counties and can program my own nx3200. I’m looking for someone who might have the details of the systems. System specific info. Nxdn systems are new to me. I believe Sumter is on a Nxdn trunking from what I read somewhere. But the database doesn’t appear that way.
kg4ojj
Crisp County, GA, USA
Sumter moved to a NXDN trunking system, and your radio won’t work without the system key from Kenwood (unless you just scan the channels in conventional mode, and most likely won’t work if the radio hears the trunking bits).
Dooly is NX9600 conventional. Database has the necessary information.
Peach is mostly encrypted, so good luck getting the key.
Medic7046
Thank you, we are in the process getting a new system which will be nxdn, pretty sure it will be conventional.With the exception of peach we are all dispatched by the same 911center and run mutual aid in peach and the others and vise verse. Im sure we will be adding their systems to our new radios.
wsp44
Sumter is NXDN trunking and I believe encrypted as well, like Kg4ojj stated, you can't program the trunking system without the system key, Dooley is NXDN conventional. What county are you in that is going to a new system? majority of the counties that border or surround that area are NXDN.
jcefd10
WWG1WGA
Macon CO is going NXDN?
Who's doing the work?
We are dispatched by MFRE911 as well.
Medic7046
Supposedly yes, they have applied for a grant. They as the county commission. I believe they are talking with Kel-rad out of Atlanta.
jcefd10
WWG1WGA
That's who did Sumter's new trunking setup. I had them do some work for me recently as well. Good guys.
