NXDN One Frequency vs Conventional NXDN Programming
UnidenSupport
Uniden Representative
Wisconsin
Actually, OFT is not conventional, it is trunking. Conventional is conventional.
I should have clarified that I was speaking of colloquialisms and the terminology is not technically correct.
VE2ZPS
Louiseville, QC
Mr. Upman,
I reiterate my question with the outmost respect for you and for uniden,
- Does Uniden is planning to work on fixing this issue ? (and is it fixable) ?
If the answer is negative, I will simply get rid of the SDS100-SDS200 and return to my two 536 and get another 436
mrscanner2008
Canada
Mr. Upman,
I also want to know if uniden will fix the problem or not ???
UPMan
In Memoriam
Arlington, TX
Right now, we have nothing to work on. The one log that was provided had a very weak signal. The receiver in the SDS200 is radically different than other scanners, and variability in performance is going to be most noted when the primary signal is very weak (as in the case logged). Under those conditions, sometimes it might be better, sometimes it might be worse. Same is true of any two receivers. Strong signal, both work well. Weak signal, one might be better or worse than the other, randomly.
UPMan
In Memoriam
Arlington, TX
Results of my tests using the Global Filter in AUTO and NORMAL mode.
As usual: exact same conditions, programming and external antenna
BCD536HP and SDS200 running simultaneously - Data collected with Proscan
Note: system 42.04 is NXDN Trunking should not have been there but kept anyway.
Can you get logs using the SDS and BCDx36HP side by side? These use the same methods/code for these functions, so it is unusual that they would have different results.
werinshades
Chicago , IL
My 536hp file #2 was running simultaneously with the SDS 200 if it helps.
VE2ZPS
Louiseville, QC
So you want lots of videos demonstrating simultaneously the 536 and 200 (as I did in the short example on youtube below) ?
If so I can provide hours if it will help
werinshades
Chicago , IL
Logs or lots, or lots of logs? :ROFLMAO:. Debug files?
UPMan
In Memoriam
Arlington, TX
Video is nice, but debug file is needed for engineering review. Even video isn't quite useful, as it does not show RSSI, Noise, Frequency, or D-Error.
werinshades
Chicago , IL
SDS200 RSSI was too low for reliable reception was all we could tell from it.
I'm confused though. I was receiving the transmissions on the 536hp and the SDS200 was also receiving them but intermittently. It was receiving reliable enough to receive and decode? Did you review the 536hp file? Both were receiving it on #2.
UPMan
In Memoriam
Arlington, TX
I don't have the tools to review log files. Engineering reviewed them. If the signal is weak, sometimes it will work and sometimes it won't.
werinshades
Chicago , IL
Ok..it appears they reviewed log file #2 on the SDS200, saw the signal was weak (it isn't very strong, it's a 20 watt NXDN system 1 mile away), but both files were recorded simultaneously and the 536 was receiving and decoding it. I'm assuming they stopped after seeing signal strength and didn't review both files in their entirety?
VE2ZPS
Louiseville, QC
Both 200 and 536 are on debug files on the same systems -
The majority of these services are small-medium size fire dept so I will leave them long enough to have a variety of transmissions samples
VE2ZPS
Louiseville, QC
My debug files will come next week;
My 20 DMR/NXDN Test subjects are Fire department and when there's no fire; ... they dont talk much.
But many of them also use it for Public Works so I should be able to obtain more transmissions during the week. (unless major fire)
I could leave them on for days but I guess my Debug Files would be huge (even without much transmission)
VE2ZPS
Louiseville, QC
My understanding is to the effect that as soon as we activate the "Debug Log to SD Card" function, it becomes impossible to track the number of hits with Proscan (both using WiFi or with the Cable) and the recording function ai also desactivated.
Therefore we submit Debug File for analysis without knowing the number of transmissions that were missed by the SDS200.
Can someone confirm please ?
In the meantime, here's my log from this morning, we can clearly see what was missed by the SDS200
werinshades
Chicago , IL
.View attachment 69320View attachment 69321View attachment 69322
What I find interesting is under the NXDN TGID it doesn't show one but in the couple one channel NXDN systems I monitor, it comes up TGID 0. One of my earlier posts I was wondering if that's the issue...scanners were inconsistently ignoring TGID 0?
VE2ZPS
Louiseville, QC
Hi Werinshades,
The problem is not related to the signal; these transmissions are all from the same systems on both machine
This morning only, there are 723 transmissions missing on the SDS200 (57%)
BCD536: 1276 transmission
SDS200: 553 transmission
werinshades
Chicago , IL
Hi Werinshades,
I did see that, and very low RSSI. What I mean is TGID is 0 on one channel NXDN systems.
VE2ZPS
Louiseville, QC
