Obtaining An FCC License
btritch
Paragould/Greene County AR
Anyone know how much it is to obtain a license for GMRS and maybe/possibly establish a repeater, Also how much an FCC license would be for a VHF Repeater Frequency Pair? Thanks For The Help..
Also, Are there any known GMRS Repeaters In Arkansas And Southeast Missouri?
gewecke
Banned
Illinois
So do some homework,and you'll have your answers! :)
n9zas
firetaz834
Metro Area, MI
Go to Federal Communications Commission (FCC) Home Page and do a search on GMRS, there you will find the needed information in regards to sumitting your application for a GMRS license and I also believe it will give you what fees are required.
Can't help you on the VHF portion, but if you do a search, you might find that answer. For results on repeartes in your area go to mygmrs.com for assistance.
davidgcet
for VHF repeater pair you would be looking at a business license. depending on who does the app for you(you will not be able to do it yourself correctly), and if any cross coordination with another approved coordinator service is required, it could be around 600-1000.00. then if the frequencies are close together you could be looking at another 3000.00 just for the duplexer. last from the ground up business 40W VHF repeater i did cost right at 14,000.00 for license/repeater/duplexer(not the expensive close spaced one either)/coax/antenna/labor. that was going on an existing 150' tower.
