OFT Programming
daddyjohn
Is there a manual, guide, or video that explains how to set up one frequency trunking on a Uniden x36hp series scanner? I want to compare the reception results using oft vs conventional programming for a conventional non trunk nxdn system. In the oft programming it also shows uid's. Is there a difference in scan times, oft vs conventional programming?
ofd8001
Louisville, KY
The Kentucky State Police is on a conventional digital system. I tried programming it as a One Frequency Trunked system. The benefit was that I saw Unit Identification numbers. However, the trade-off was a bit of a delay in "latching on to" the channel. Not bad, but enough to make me say "forget the One Frequency Trunked method".
