Thanks for the help, got it to work, how do I add a wildcard, not understanding that part
To Add a Talkgroup ID with the Scanner
1. Press the Menu button until 'Main Menu' is displayed.
2. Press ▼ or ▲ to select 'Program Menu' and press SEL/►.
3. Press ▼ to select 'Edit System' and press SEL/►.
4. Pressing ◄ or ► will scroll through the systems. Press and hold ◄ or ► to scroll faster.
Press SEL to select the System to add the talkgroup (ID) to.
Press ▼ to select 'Add Talkgroup' and press SEL/►.
The talkgroup defaults to a Wildcard talkgroup.
Press SEL to save and enter the settings menu to set your options.
The first lines will show:
Cancel Changes
Save Changes
You can also look for the. . .
Add Wildcard (button) Allows you to add a wildcard ID that will receive all talkgroups (Talkgroup Details tab) or a wildcard ID that will receive all private IDs (Radio ID Details tab). Click the button to create the wildcard. Scroll to select and click the scan list(s) you want the wildcard ID assigned to and click the Set button. Note: If a wildcard already exists the button will be grayed out.
These instructions are from the "Easter to Read WS1080/1088 Manual"
Easier to Read Whistler WS1080/1088 Handheld Scanner and Software Manual
The TRX-1 is basically a WS1088 with more bells and whistles; the 1088 is a WS1080 with full keypad.
