Gilcrease is online today ID 1953.
Will phase 2 be system wide
If someone can come up with money to upgrade the site controllers to the current model, sure.
Norman's currently speccing out new equipment for Site 40 from their Public Safety Slush Fund. I'm sure it will be Phase 2 (since that's the current hardware/software). I have not read the RFP that has been floating around so I don't know if they plan to stay connected to OKWIN or not. Tulsa obviously has an independent source of taxpayer money to update their site(s) as well since they are doing it. Dunno about Edmond or Shawnee.
The state has a buck 3.80 to spend so I don't see them rushing to replace equipment that is currently functioning correctly.
Thank you just wanted to know how quickly I'm going to have to upgrade.
If you have a current P25 scanner, you can listen to all of it right up until the point that the Powers That Be decide you are no longer allowed to listen to your public servants at work and order that encryption be enabled. Then it doesn't matter what radio you have.
Seeing some new ID's, 2273 I believe and it sounds like Tulsa Transit. Also I don't know if my PSR-600 is having trouble with TPD Gilcrease or they went Encrypted or Phase 2. Also seeing 2241 ID showing up.
