kc2klc
I'm successfully using SDRTrunk on my Windows PC with an RTL-SDR to monitor our local emergency services, which use APCO-P25 Phase II. However, due to the RTL-SDR's 2 MHz bandwidth limitation, I only have 5 of the 6 utilized frequencies programmed in. The assigned frequencies are:
Ch. 1: 453.2750
Ch. 2: 453.4250
Ch. 3: 453.8375
Ch. 4: 454.3000
Ch. 5: 454.4750
Ch. 6: 460.2875
(Channel 3 is currently being used for control; that may eventually switch to channel 1).
I have several questions:
(1) Am I correct that I cannot include Channel 6 because it is outside the 2 MHz bandwidth of the other channels (unless I add a second RTL-SDR)?
(2) If that's the case, am I potentially missing much without it?
(3) When I eventually get SDRTrunk running on my Raspberry Pi, will I be able to copy over the default.xml file from my PC so that all the talkgroups I programmed in remain intact?
Thanks!
Ch. 1: 453.2750
Ch. 2: 453.4250
Ch. 3: 453.8375
Ch. 4: 454.3000
Ch. 5: 454.4750
Ch. 6: 460.2875
Thanks!
