On ground antenna tacking
krokus
Southeastern Michigan
For those that have installed a LoG, BoG, or DoG, what did you use to tack down wire element(s)?
The staples for "invisible fence" wire, or for garden cloth, seem like a reasonable option. Even small tent stakes, or the small metal stakes that come with some pop-up shelters would be overkill.
vagrant
ker-muhj-uhn
California
I occasionally setup/use a LoG, so I just use plastic tent stakes to anchor at least four points. I also have plenty of ground cover staples left over from projects, so I would probably use those for permanent use.
