On the green or on the red
rfp237
Rochester’ NY
Listening to my local EMS communications, every call is either “on the green” or “on the red.” I assume this corresponds to the urgency of the response, but can someone tell me exactly what it means?
As @tvengr said, you'll get better responses in the NY forum, here it is people across the country guessing. That said, in my area green/red means accepting patients or full and not accepting.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Which agency are you listening to?
And what’s the context of the phrases? How are they used?
rfp237
Rochester’ NY
Actually, there are two ambulance services in my area. One categorizes each call using priority 1, priority 2, priority 3 or priority 4. The other uses this on the green or red terminology. After the dispatcher describes the emergency and the location to the ambulance crew, the dispatcher repeats the the location and then says “on the green” or “on the red” and the ambulance crew repeats the location ”on the green” or “on the red.”
SteveC0625
Why be vague about who the ambulance companies are? Most likely it’s AMR and Monroe. AMR uses the Priority Dispatch EMD code information to categorize 1through 4 because that info is send to them via 911’s CAD dispatch. They have the City of Rochester EMS contract so much of their call volume comes from 911. Monroe has some coverage out in the county but does a considerable volume of private and transfer calls. They do get the 911 CAD info for any county area where they have response contracts.
jaspence
Michigan
An analog system I used to monitor had a green channel and a red channel (and other colors) because it was easier than remembering frequencies.
Bob1955
Eastchester, NY
A red tag is someone in critical condition and a green tag is minor. ALS-Advanced Life Support /BLS-Basic Life Support.
Also, for Fire Departments. If the dispatcher says to go with traffic, it means no sirens and follow all traffic laws-meaning a non-emergency call.
bob550
Albany County, NY
Unless there's been some other code words for, or direct reference of, Covid-19, I'd say these color codes are a reference to that. I don't hear many local EMS calls that don't clarify that for the responding EMT's.
sallen07
Rochester, NY
Red is lights and siren. Green is ... not.
If you hear an EMS unit report that they are heading to the hospital "ALS Red" that is NOT a good thing.
