One county
I can not find EZ-scan on my TRX 2
It is the software you install to program the scanner. It should be on your PC or laptop.
Ubbe
Stockholm, Sweden
As well as firmware updates.
Whistler has a stand alone program for firmware upgrades that can be downloaded from the their site whistlergroup. But there's no 3:rd party scanner programming software so you'll anyhow end up using EZ-Scan. But that stand alone program are the only one I can use if I don't want one communication failure after the other during upgrade attempts.
/Ubbe
tvengr
Well Known Member
Baltimore County, MD
Being in Denver NC in Lincoln County, there are 2 sites you should have programmed. In addition to the Lincolnton site, you also need to include the Anderson Mountain site in Catawba County which is far closer.
This will only help him, based on the original post, if he limits the TGs to the one county.
