Which brands support Motorola Connect Plus without affiliation?
I didn't think Motorola had licenced CP to any third party manufacturers.
I have the Tytera Md-380 with the firmware hack. I looked up all the Frequencies at the Hartford site. A couple came back to Systems like Marcus etc. But most said not found when I looked up on FCC Database. If anyone has any luck which voice channels to try. list them here and I will try...Thanks
Alec
I think the best way to answer that would be to contact the system operator (or visit their website) and ask if they offer encryption.
There are some assumptions about this system that appear to be hard-coded into the relevant Wiki and cannot be edited around.
Here are some updates and corrections:
This network covers a larger area than the map shows. Repeater Network, LLC, also holds several licenses for sites that are part of this system and the coverage extends into the lower Adirondacks. (see WQMX625 through 628)
Site locations are difficult to determine because, at least in the case of Repeater Network, LLC, these are Part 22 spectrum licenses with blocks of frequencies and market areas, rather than discrete channels and transmitter sites.
I could not figure out how to add color codes anywhere without creating new tables for each site.
Site 25 (unknown) Color Code: 4 on Control Channel: 454.43125 MHz
Site 41 (Austerlitz) Color Code: 5 on Control Channel: 454.16875 MHz
Neighbor information would also be useful for closing up the knowledge gaps.
Site 25 neighbors: 22, 23, 41
Site 41 neighbors: 20, 22, 23, 25, 40
My best guess for Site 25 at the moment would be Pinnacle or Helderburg Mountain.
I am using dsd to listen to this system. The audio decodes pretty good on the talk groups. However, tg 30421 seems scrambled . Could it be encrypted or voice inverted?
If you are hearing multiple TGs clear and one garbled, it is almost certainly encrypted.
You would see the normal line in the Event file but at the end, you would also see something like
Alg=EP KeyID=3
That means Enhanced Privacy and using the key that was entered into key position 3 in the radio
chris
