Op25 and Airspy
philacop
Clifton Hgts PA
Hi
Trying to set up my Airspy to run OP25..
I currently have it set up using a RTL sdr and need to know what commands need to be changed to what to change from the RTL dongle to the Airspy ?
wgbecks
NE Wisconsin
The Airspy R2's and Mini's have three distinct gain modes; Sensitivity, Linearity, and Custom. My personal preference has been to make
use of the "Custom" gain mode whereby LNA and Mixer AGC are disabled allowing me to optimize LNA, Mixer, and IF gain values for
best overall performance.
The following is an example of rx.py configured with an Airspy R2 operating in the "Custom" gain mode.
./rx.py --args 'airspy=0,sensitivity=0,linearity=0,bias=0' -N 'LNA:15,MIX:12,IF:8' -S 2500000
Note: The R2’s sample rates (-S) are 2500000 and 10000000 while the Mini's are 3000000 and 6000000 respectively. You can also specify
the actual device serial number for applications where two or more Airspy devices will be in use.
philacop
Clifton Hgts PA
Thanks wgbecks !!
