I have been running OP25 (boatbod) on a Raspberry Pi 4 using a Nooelec SMArt stick quite successfully for the past few months. Suddenly, in the past few days it has stopped working with no changes made by me. I have tried a second stick and a different antenna with no change in results. Formerly my Constellation plot showed four very tightly clustered groups in the corners. Now, the plots are scattered all over. I am running rx.py rather than multirx. Here is the command that formerly worked and now fails:
./rx.py --nocrypt --args "rtl" --gains 'lna:36' -S 960000 -l "http:0.0.0.0:8088" -X -q 0 -v 1 -2 -V -w -U -T trunk.tsv 2> stderr.2
Here is stderr.2:
Using Python /usr/bin/python2
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.13.4
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Nooelec NESDR SMArt v5 SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gain: name: LNA range: start 0 stop 0 step 0
setting gain lna to 36
supported sample rates 250000-2560000 step 24000
Using two-stage decimator for speed=960000, decim=10/4 if1=96000 if2=24000
op25_audio:pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1], do_nocrypt[0]
01/25/23 07:51:45.823151 Reading whitelist file
01/25/23 07:51:45.823407 added talkgroup 3697 from whitelist.txt
01/25/23 07:51:45.823523 added talkgroup 3701 from whitelist.txt
01/25/23 07:51:45.823625 added talkgroup 3703 from whitelist.txt
01/25/23 07:51:45.823723 added talkgroup 3705 from whitelist.txt
01/25/23 07:51:45.823820 added talkgroup 3707 from whitelist.txt
01/25/23 07:51:45.823920 added talkgroup 3709 from whitelist.txt
metadata update not enabled
using ALSA sound system
audio device: default
Listening on 127.0.0.1:23456
python version detected: 2.7.16 (default, Oct 10 2019, 22:02:15)
[GCC 8.3.0]
Allocating 15 zero-copy buffers
01/25/23 07:51:46.949613 control channel timeout
01/25/23 07:51:48.040730 control channel timeout
01/25/23 07:51:49.130322 control channel timeout
it seems that op25 cannot lock onto the control channel. Any suggestions on where I should be headed to troubleshoot this further?
thank you.
Here is stderr.2:
[GCC 8.3.0]
thank you.
