Orion Software error=0303
Tom_G
Rocky Hill, CT
I have looked up error messages in their documentation and I can not find that error code.
I receive the error intermittently when the radio is scanning. It will flash on the screen to a couple seconds and then the radio will restart and resume scanning.
Has anyone seen this error before? Thanks,
merlin
DN32su
Sounds like a VCO slipping out of lock. An alignment of that section will solve that.
Manually going through channels, any that hesitate, rapidly go back and forth and may produce the same error.
That would confirm the problem.
0303 is sort of a catchall for a synthesizer issue.
A fast Q, does the radio unmute or get a channel busy light at that moment ?
Tom_G
Rocky Hill, CT
I should have known that if anyone knew about this, it would be you... Appreciate all your help
The radio is actually scanning an EDACS system when I receive the error.
I will try to watch for a busy light when the error happens. Its intermittent, but it will happen a couple times in a 15 to 20 minute period.
Otherwise, I can reprogram the radio with the same frequencies but only in conventional mode so I can step through them manually.
These are the frequencies in use.
01 854.9625c02 856.437503 857.437504 858.437505 859.437506 857.937507 857.987508 858.7125
09 858.937510 858.987511 859.737512 859.987513 854.012514 856.0375
Thanks for the tips...
Tom_G
Rocky Hill, CT
So manually going through the channels seemed ok, and did not reproduce the issue.
I'll keep looking for answers. Thanks
