Ok then. It’s time to call Uniden repair. They charge a flat rate of $80 to repair and an additional $10 for shipping it back to you.I can't plug it into the wall without battery,
when I put the battery charge already it says that my batteries are discharged and I connect it and it does the same.
And for the sound there is nothing just a little background noise
Energizer Ultimate Lithium is a AA size battery that is acceptable to use in the handheld scanners that call for AA batteries. I’ve been using them when I attend airshows due to their extended life (not to mention reduced weight). Yes, a lithium ion battery has a higher voltage per cell so the energizer bunny must be doing something to throttle back the voltage... either it not a “true” Lithium ion or it’s got some sort of dropping resistor built in? Don’t k ow for sure. But the answer to that is just a google away.Isay something is going on or something that happened you did not mention. You sure you are using AA nimh or nicad, and not lithium batts. Lithium batts are more voltage which will give you the "llegal voltage" warning.
Ummm...last I heard is lion batts are higher voltage...someone please correct me if I am wrong but that is one of your first mistakes. Is it that difficult for you to buy regular mimh batteries that you have to resort to lion batts? That is a BIG NO-NOYou said you installed a new battery. The 436 uses 3 batteries. Are the other batteries rechargeable? If not, that could cause the overheating.
Tvengr- this isn't directed to you. N1chu- bud you are gonna fry your radio. Just because it is same size don't mean its gonna work. Those batts are higher voltage than reg batts and higher than nimh,/nicad batts.Ummm...last I heard is lion batts are higher voltage...someone please correct me if I am wrong but that is one of your first mistakes. Is it that difficult for you to buy regular mimh batteries that you have to resort to lion batts? That is a BIG NO-NO
"The nominal voltage of lithium-ion is 3.60V/cell. Some cell manufacturers mark their Li-ion as 3.70V/cell or higher. "Ummm...last I heard is lion batts are higher voltage.
