I have a mobile dual band radio capable of anywhere from 5-50 watts, with a permanent roof-mounted NMO antenna near the rear of the roof of my SUV. About 4ft away near the front of the SUV, closer to the top of the windshield, I have a mag-mount NMO antenna connected to my 996P2... I noticed while tuned to a constant broadcast frequency in the 450Mhz range, and transmitting with the dual bander in the 440 range (I believe I was first at 50 watts, and then it still happened at 25 watts), the scanner audio cut out for the duration of the transmission, and came back as soon as I un-keyed my mic.
My question is, if I replace that mag-mount with a 2nd permanent NMO hole for my scanner antenna and run this as my setup, will I risk damaging the scanner every time I transmit? Is this effect of apparent overloading due to the proximity of the two veritcal antennas perfectly acceptable to repeat/allow for longer tx durations, or is it evidence of what will eventually amount to cumulative damage? I'd like to know before I drill. Thanks!
Bonus question: I'm also considering including a CB antenna halfway between the two existing antennas, 2ft from the front antenna and 2ft from the rear antenna, a total 4ft spread for all three (I was going for max distance between similar freq antennas)...considering the much larger frequency gap, do I have anything to worry about with regard to once again overloading the scanner or any other general antenna proximity considerations?
