P1225 Programming
NCFire11
I have a couple of old P1225's sitting around that ive sniped off of ebay, that are basically no use to me since I cant program them.
I need to know, does the P1225 Software(HVN9054C) work on my XP machine? The software pulls up fine but I was told it may not work right.
And my PC doesnt have a serial port so will a USB>RS232 converter work? I have the Cable coming in.
Good luck
I can't get the P1225 software I have to work with XP or NT.
GP300 software runs fine on both machines, and the P1225 is a newer handheld.
I give up on programming them, they just sit getting dusty in a box.
We had one old machine that would do them, but someone threw it out.
NCFire11
I have the GP300 software and HT1000 software as well. Is it supposed to run in a little DOS looking box while in Windows? or do you boot into the software?
KG4INW
Midlothian, VA
Run in pure DOS only. It'll cause all sorts of headaches if you run it under any form of windows.
davidgcet
you need to find an old pc and a copy of win 95/98/2k/ME. for the P1225 use windows. for the older stuff F8 and boot to a command prompt.
i've had the 1225 work on both XP and even vista. but it was a pain to get it working and i don't remember how we did it. i just keep an older laptop for programming those radios.
NCFire11
For the P1225 it comes up fine but I dont have the cable yet to test it. Ive heard that it can have problems running on Xp because it wont read/write for some reason. What about the Usb to rs232 cable to plug the cable into?
davidgcet
that will work for the P1225, just set the port so it is 1 or 2. won't work for the DOS programs though, for tha tyou must have a physical port.
Cable or charger
I dunno if they make just a programming cable for it. What I have is a drop in charger/programmer, with a 25 pin D-connector on it, that goes into the RIB box.
NCFire11
they make both, one that you take the battery off and slide it on there(it looks like a battery itself) and the other that you seem to have you drop the thing into what looks like a charger. The one that looks like a battery is RIBless, the rib is built into it.
davidgcet
even though i work for a MSS we never bought the official cable. goto batlabs.com and they have instructions for building a ribbed or ribless cable.
K4APR
Chesapeake, VA.
When I was still working at a Moto shop, we kept a Win 3.11 machine working for P1225, since it seemed to run the RSS well. However, several years back, before I left that shop, Moto updated the P1225 RSS to run under XP and it was available at the time from MOL (with a license of course!). You might want to check with Moto and see if that is still available and how much. Won't be cheap, I am sure of that, but you could probaly alleviate any software problems by going with the version meant to run under the NT kernel ie. XP, W2K, ect.
Good luck.
SD70MAC
NC
p1225
I have never had a problem with Rss 4.0 P1225/m1225 on XP PRO but NEVER use a USB cable. The only radios that were designed to use USB is the XTS/APX lines and some very cheap radios. The USB cable will get you at some point.
NCFire11
Well considering I paid my $300 for the Rss already i dont really want to pay for a newer version for XP. Would the USB cable work if it came down to it?
davidgcet
i have used a usb to serial adapter to connect my rib under 2k and xp. it HAS to be setup for com 1 or 2, 3 and up would not work for me with my belkin.
