P25 Decode for the Uniden 996T
W9NES
Indianapolis,Indiana
Can anyone tell me how to get into the menu to get the Uniden 996T to go from 50-200 and be able to adjust this the way I did for the Uniden 396XT. If anyone can help explain this to me that would be great in a step by step way that would be great.I have tried to use the Uniden post fo the 996T but cannot get the radio to get the P-25 settngs to come up on the screen.If anyone can assist me that would be great.Thank You.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I believe that the P25 adjust mode was only available on the XT models....73 Mike
W6KRU
Vista, CA
The T models offered options that the XT models do not have. The XTs only have an Auto setting and the T models had a manual adjustment mode.
P25 audio decode level adjustment - The RadioReference Wiki
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Actually Dan it's the other way 'round. The XT models have 3 additional options that aren't available on the T models...the decode threshold is about the only thing you can change on the T models...best regards..Mike
W6KRU
Vista, CA
I disagree Mike. The OP is asking about options for his 996T. The T models have a a P25 Manual adjustment mode that is not available on the XTs. Which scanner has more features? MEH? The manual setting is superior to the auto setting and the three additional options. It is accessed by going to Site Options:
Adjust P25 Level This setting determines some system-specific parameters for digital channels. In most cases, setting this to Auto provides the best performance. However, you can also manually set the digital decode threshold. This setting affects all digital channels in the current system.
Scroll to 'Adjust p25 Level' and press E/.
Scroll to one of three settings and press E/ to save and exit.
Auto- the scanner automatically adjusts the digital decode threshold to match the transmission you are hearing when it receives a strong signal and has a high decode rate.
Manual- lets you manually adjust the digital decode threshold.
Default- sets the digital decode threshold to the default value. This is handy if you have manually adjusted the value to a setting that prevents proper decoding.
The decoding is adjusted using the procedure in the wiki that I linked to earlier.
