I agree, which is why I mentioned that this would be highly unusual and absolutely the last thing to place blame on. Probably under the 2-5% probability of that being the problem.
Barring any changes to the radio like location, antenna change, dropping it, or new nearby construction, the most probable cause is a change to the radio system you're monitoring. This can be their addition of new antennas, changes in band due to rebanding with CCs remaining the same (this happened in my area) or lots of other reasons. Couple of things you can do is take the scanner for a short ride and see if the reception improves in other near locations, for one. Try another radio, if available, to verify if it's your location or the receiver.
Lots of options to try first.
