For years everyone that's had one of the BCD996T, BCD996XT or BCD996P2 scanners has generally had problems with distorted, garbled audio on P25 Simulcast systems using CQPSK / Linear Simulcast Modulation.
I've seen many threads, including one that mentioned the problem cannot be solved by firmware because it's a hardware problem with these scanners and Uniden's only answer was to design and release the SDS line of scanners.
I'm wondering if anyone has considered a diversity antenna system for 996 series scanners? Technically, I don't know what would be involved to integrate the idea - is it a radio hardware / multiple receiver in one scanner deal or is it simply building a diversity antenna system and feeding it into the Uniden scanner antenna port. I do know that the purpose of diversity receive antennas is to combat multi-path and it seems like that might be a solution for those of us with the older scanners.
Second question: How do the BCD536/436HP Scanners / Home Patrol scanners perform with LSM systems? I've not tried either. I DO know none of the above work well and the SDS-200 I've got to observe seemed to handle LSM flawlessly.
