P7100 P25T Group System ID field
twl911
I am trying to program a P7100 P25T, My system ID is different than the system NAC.
No matter what I do the system ID field under group options remains greyed out and un-editable. The help file mentions this as a lockable field, but I see no where to lock-unlock it.
I've come along way with my Harris programming thanks to the help from this forum, but this one has me stumped?
Forts
Ontario, Canada
You don't enter the system ID in the groups section... it goes in the P25 Wide Area Networks section.
Since it would appear you aren't familiar with setting up a trunked system be extremely careful with what you are doing.
twl911
Forts, I was hoping you would reply, you have been very helpful in the past with my migration to Harris software.
I guess my field names/terminology is probably wrong.
I have the WA system setup under the P25 system screen,
set the WACN under networks,
then the system NAC.
The only place I see the system ID field is under group sets, and it is not changeable. Where can I set the system ID? I find no field that allows entry.
I have a very good idea of what I am doing with trunked system programming, the potential of mis-use/programming errors and have a good Harris cheat sheet and double check the appropriate boxes everytime I open the software, but RPM is still a learning curve. I am using RPM 14C05 with the hacks, could my software install be the issue? It allows my to program the trunked system to and from the radio, so I assume the AAC is setup properly?
Forts
Ontario, Canada
System ID goes in Options/P25 Wide Area Network Options
Network Address (WACN) is the WACN.... BEE00 etc
System/Region ID is the SYSID
Under Systems/P25 Trunked... for each individual system you select your WA network (from the ones you've already setup) then if needed you can specify the System NAC, Site and RFSS IDs.
Hopefully that helps. The only thing you should need to enter into your group sets are the talkgroups.
