PA Federal Frequencies
Scanner996p2
PA
So I have been searching through many of the common federal frequencies in the US but also in the state of pa. For example I live in York county pa which is southern pa. What federal frequencies are known of to be used in that area. Or do I have to put them all in and hope I get lucky? Any help would be appreciated.
The best suggestion is to search the federal bands for activity, the amount of activity really varies by area.
162-174.000 MHz
380-400.000 MHz (usually trunked systems in this band)
406-420.000 MHz
There is a list of fed freqs in PA listed in the database
ecps92
Taxachusetts
162-174.000 MHz
406-420.000 MHz
I would add to those 400-420 vs 406-420, as there has been LMR (Non Satellite) found in use
and add the 137-144 and 148-150.7000 bands
And keep in mind, Federal Monitoring is not quite like your local PD/FD/DPW/EMS
you may find nothing for weeks or months, then a fury of activity and then nothing for years
Keep searching and make copious notes, such as CLR/ENC , location/street names or even channnel names
along with the PL/DPL/NAC found
Marcy57
Long Island...NY
I can attest to that! ...I copied N301 on 162.050 very briefly
in December and daily have been on that freq. and nothing
almost 5 months seems they do not use it much or a one
off brief activity situation?...Marcy
