Painting a whip antenna
Fury853
Alleghany County, Virginia
I am working on blacking out some things on my SUV and was thinking about blacking out my Ball mount, spring, and whip antenna! Does anyone have any ideas on what I could do? i thought about spray painting it. But would that work on the stainless steal? also would that affect the signal any?
n5ims
KD0TAZ
Kansas
I've used plastidip on a few things. It'll work fine on the ball but I wouldn't recommend it for the whip or spring because the smooth steel surface and constant flexing will cause it to peel off pretty quickly. Heat shrink is a good option for the whip. You can get 4' and 8' lengths from many sites. And just spray paint the spring.
Sent from my Galaxy SII using some Tappity Talkity thing.
gewecke
Banned
Illinois
Flat black rustoleum works well for this. :wink:
73,
n9zas
ridgescan
San Francisco, Ca.
Well mine for one already came black and is a scanner antenna so not quite the same as what I think you have.
The Plasti-dip site has rubber products as well that will work on the steel.
