PD682 no audio
Remington12G
GØT AES?
I wrote my codeplug to my PD682 and there is no power on sound, no TPT Tone, no audio coming through when I transmit on my Kenwoods nut it will pass my audio to my other radios. Any ideas?
Silent Radio is turned off under Alert Tones
dazey77
first things first, write the default codeplug back to it and check you have audio. Assuming the radio is OK then work from there. For weird happenings I have found this to be a good way of debugging on Hytera. (Program menu/Reset Default Data)
Remington12G
GØT AES?
I tried that, got a message that the CPS Data is not up to date with the radio data.
dazey77
Perhaps try a later CPS? Not sure what firmware the radio is on or the CPS your using. Latest easily available at the mo is CPS 9.02.02.002 and firmware 9.02.02.004
Do you have any old codeplugs you can put in? Or is this the first one you wrote to the radio?
Remington12G
GØT AES?
The seller was going to make an older codeplug for me when he has time. The CPS is 8.06.01.017 and the firmware is A8.05.07.004. I think the radio thinks it has a speaker mic or some audio device attached since it won't pass audio through the speakers but will function and operate everything else.
dazey77
Hmmnn, its odd that it won't write default data then. I would certainly have expected that combination to work.
