PD752 to monitor connect+ system...
ECFD
KEA536
Hi all,
First off I'd like to apologize if this is the wrong place to post this, and I'd like to clarify that I've looked around on here quite a bit and haven't found exactly what I'm looking for. I'm trying to use a Hytera PD752 to scan the Lancaster site of the SaiaNet connect+ system in Buffalo NY. I'm only trying to receive 4 relatively inactive talkgroups, being both LVAC ambulance dispatches as well as the two fire dispatch talkgroups for the Buffalo-Niagara Int'l Airport. I have the 3 voice channels of the Lancaster site programmed in conventional mode and set to pseudo trunk, and the control channel is programmed for slot 2 only. Multiple coverage maps show I'm well within range of this site, and while I do receive bits of conversation, it's occasionally a bit garbled and I often lose pieces of conversation. Granted I don't expect it to be perfect, but I'm wondering if anyone has any tips or tricks to get it to follow the conversations a bit better. The only thing I can think of would be to play with the group call hang time and/or the scan rate for my scan list. Do connect+ systems generally stay on a single talkpath for the duration of a group call or can it change rapidly? If these systems do tend to stick to a single talkpath, ie frequency and time slot, during a given group call, is there a specific setting I should modify to try and match this to follow the conversation or have the radio unmute quick enough to hear the first part of the conversation? Thanks in advance!
Chris
Muxlow
Super Secret
Middlesex County
It will work to scan but not transmit.
Iv scanned a couple connect + systems same way. Program each voice frequency and set for pseudo and correct color code, add to a scan list and your good to go. Unless the moto repeater is transmitting a RAS then your sorta stuck. Or if they use basic privacy.
Just for the hell of it if you have send talker alias enabled, try shutting the off. Iv had issues with hytera radios with that enabled not working 100% with motorola, but shut that off and all is good
