You don't need to set Trunkview up as it's not as easy as UniTrunker. Just use it to grab the voice channel ID's. Or run UniTrunker. UniTrunker is easier to setup the multiple ranges on the band plan so the LCN's are converted to frequencies correctly. Use the ranges that I posted earlier in the thread.site 53a9 is my strongest, so how do i set up trunkview, what is my base freq and do i use 6.25 for the step?
000-161 451.000000 453.012500 12.5kHz
162-213 454.018750 454.568750 12.5kHz
214-364 460.650000 462.525000 12.5kHz
365-508 463.200000 464.987500 12.5kHz
18:14:59 ******* TrunkView :: MPT1327 Protocol Decoder ------ Monday 2013-01-14 **********
ID: 54B9 | PG&E | Cch Frequency: 454.48125 MHz
18:19:13 - AHYC | Short data invitation message | (001) Org: 1774 Tar: Short data message ident Slots: 2 Desc: 4
18:19:14 - ACKQ | Acknowledge, call queued | (001) Org: 1774 Tar: 8136
18:27:49 - AHYC | Short data invitation message | (001) Org: 1751 Tar: Short data message ident Slots: 2 Desc: 4
18:27:49 - ACKQ | Acknowledge, call queued | (001) Org: 1751 Tar: 8136
19:09:51 - GTC | Go To Channel - Voice | (000) Org: 2741 Tar: 6501
| Ch: 199 Freq: 454.48125 MHz |
19:10:26 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
| Return to Control Ch: 94 |
19:10:27 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:05:36 - AHYC | Short data invitation message | (000) Org: 3079 Tar: Short data message ident Slots: 2 Desc: 4
20:05:37 - ACKQ | Acknowledge, call queued | (000) Org: 3079 Tar: 8136
20:06:37 - GTC | Go To Channel - Voice | (000) Org: 2770 Tar: 6511
20:06:38 - GTC | Go To Channel - Voice | (000) Org: 2770 Tar: 6511
20:06:43 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:10:34 - AHYC | Short data invitation message | (000) Org: 3079 Tar: Short data message ident Slots: 2 Desc: 4
20:10:35 - ACKQ | Acknowledge, call queued | (000) Org: 3079 Tar: 8136
20:10:53 - AHYC | Short data invitation message | (000) Org: 3079 Tar: Short data message ident Slots: 2 Desc: 4
20:10:54 - ACKQ | Acknowledge, call queued | (000) Org: 3079 Tar: 8136
20:15:49 - GTC | Go To Channel - Voice | (001) Org: 1671 Tar: 6741
20:16:15 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:16:16 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:16:26 - GTC | Go To Channel - Voice | (001) Org: 1671 Tar: 6741
20:18:05 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:18:06 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:29:08 - AHYC | Short data invitation message | (001) Org: 2497 Tar: Short data message ident Slots: 2 Desc: 4
20:29:09 - ACKQ | Acknowledge, call queued | (001) Org: 2497 Tar: 8136
20:30:54 - GTC | Go To Channel - Voice | (001) Org: 1671 Tar: 6741
20:31:48 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:41:35 - GTC | Go To Channel - Voice | (000) Org: 2859 Tar: 6511
20:42:25 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
20:42:26 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
21:03:25 - ACKI | Intermediate ack, more follows | (001) Org: 1755 Tar: 6743
21:03:26 - GTC | Go To Channel - Voice | (001) Org: 1755 Tar: 6743
21:04:26 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
21:04:27 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
21:09:24 - GTC | Go To Channel - Voice | (000) Org: 2679 Tar: 6511
21:10:21 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
21:10:22 - CLEAR| Call clear-down | Ch: 199 Freq: 454.48125 MHz
21:28:49 - AHYC | Short data invitation message | (001) Org: 5442 Tar: Short data message ident Slots: 2 Desc: 4
21:28:49 - ACKQ | Acknowledge, call queued | (001) Org: 5442 Tar: 8136
21:37:35 - AHYC | Short data invitation message | (001) Org: TSC ident Tar: 1755 Slots: 1 Desc: 0
The "Call clear-down" message indicates the Voice Call is finished, and to return the radio units to monitoring the Control Channel.21:09:24 - GTC | Go To Channel - Voice | (000) Org: 2679 Tar: 6511
what does call clear down mean?
Channel 94 is the Control Channel of that Site.(452.1750 MHz ?)Return to control channel 94, does this mean this tower release control to site 94?
Some observations from the south bay (N. San Jose, Santa Clara County). Channel numbers in [brackets].
Control channel | Adjacent sites
5089: 454.0950[168] | 5099[205] 50B1[170] 50C1[172] 50F9[197]
50D9: 454.1075[169] | 5091[171] 50C1[172] 50D1[196] 50E1[195] 50F9[197]
50B1: 454.1200[170] | 50C1[172] 50D9[169] 50A9[703] 50D1[196] 50F9[197]
50C1: 454.1450[172] | 5089[168] 50B1[170] 50D9[169] 50F9[197]
50F9: 454.4575[197] | 5089[168] 5099[205] 50B1[170] 50C1[172] 50D9[169]
53F9: 454.5200[202] | 5099[205] 50A1[204] 50C1[172] 50E1[195] 50F9[197]
50A1: 454.5450[204] | 5089[168] 50F9[197] 5189[436] 5199[197] 53F9[202]
Voice activity on 454.1575[173] and 454.4200[194]
CW IDs:
454.0950: WPVE246
454.1075: WPVE246
454.1200: ??? Too weak to ID
454.1450: WPVE248
454.1575: WPVE248
454.4200: WPVE256
454.4575: WPVE257
454.5200: WPVE260
454.5450: WPVE261
OK, a bit confusing. You have 454.48125 MHz shown as the CC, as well as for the GoTo Voice channel, and while I am aware of Motorola's VOC (Voice On Control), and EDAC's version, SCAT, I am not aware of any such feature available for MPT1327.18:14:59 ******* TrunkView :: MPT1327 Protocol Decoder ------ Monday 2013-01-14 **********
ID: 54B9 | ................PG&E........................| Cch Frequency: 454.48125 MHz
They are still rolling out the system, so there is probably not many users on it yet.. . but after monitoring it all day with unitrunker and trunkview, i never recieved any voice channels into either logs, any ideas?
Then I wouldn't be too concerned about Clear-down messages, or lack of Goto Voice messages, until such time as the network has settled down.Im running a GRE 600 scanner, so there is no control between trunkview and the scanner, it is parked on the control channel only.
That was my screw-up in my original post. I'll fix it.According to my calculations, 454.568750 is Ch 206, and Ch 213 is 454.656250
Download a program like 7Zip. This will allow you to ZIP and make it way smaller. Use the ZIP format and not 7z as the board only supports ZIP.i figured out how to make it a txt file, but its to large to post, if you pm me your email, ill send it to you
