Pl code
brog83
OHIO
the pl codes listed on this site, are they for both transmitting and receiving?
brog83
OHIO
pl codes
so how can I get the PL code for transmitting? would the agency I work for be able to give it to me?
K8TEK
Banned
Ohio
They probably could. You could always listen to the repeater input.
captclint
Mountaintop, PA
9 times out of 10, they are the same as receiving. If you don't know that, and it is not listed in the DB, then most new scanners have PL/DPL decode. You can sit in the parking lot with a scanner and get it whenever they transmit. Borrow a scanner if you don't have one.
firefighter89
Startex, SC
Most of the time they are the same. If it's a repeater, listen to the input. If it's simplex then obviously it's the same PL for transmit and receive.
ecps92
Taxachusetts
Yes, the Agency you work for, would have to give them to you. Especially for Transmitting. Besides the PL you need to know if your agency is still Wideband or now Narrowband and if your two-way is compliant on the network. They need to know what radios are on the network.
