They're typically good for many, many, many strikes. A system I worked on has been using the same PolyPhasers in VERY lightning-prone areas for almost 8 years. You will start seeing higher reflected power if a PolyPhaser has gone bad. Unfortunately, a bad PolyPhaser is not the only thing that can cause reflected power...and I recall that most of the very basic models are a DC short (except for units to use with RX antennas that have tower top amplifiers, then they use a different model that has DC continuity). Maybe someone else has a better way to test.
