Has anyone checked out the Malachite (also seen as Malahit) radios? The noise reduction is impressive.
If you listen late afternoon, as dusk falls on time zones to your east, you'll often be able to pick up much more distant stations from the east. The local stations are still almost entirely ground wave because it's daylight but those to the east are in advancing darkness and you'll get a bit of atmospheric bounce. It translates to less interference from locals (on the right frequencies) and stations to the west and a better shot at hearing those more distant stations to the east.Can’t wait till dusk to see how it performs at night.
I agree but the radio can make it easier to make fine tune adjustments. I played around with it and the TERK antenna last night and was able to fine tune some stations I could identify from Chicago, Colorado Springs, and Atlanta (from Dallas). I switched to the 9khz setting and was able to pick up some other stations I could not identify. Setting the TERK to the right of the radio so I could pass my hand through the loop to make changes on the radio worked extremely well. Changing the radio frequency and then changing the knob on the TERK about the same amount really made a big difference and it easy to fine tune weak stations.As to night time performance, any halfway decent radio can pick up distant stations at night. It's really not the test of radio quality most people seem to think it is.
The Terk is unlikely to improve reception on the EP-Pro except under extreme conditions where you can combine the nulling ability of both antennas. The twin-coil adjustment knob on the EP-Pro already gives you the ability to peak the antenna output for the tuned frequency. The tuning knob on the Terk does exactly the same thing on the Terk. I think if you use the EP-Pro alone, adjust the TC for the tuned frequency, then rotate the radio to best isolate the desired signal, you'll get pretty much the same reception as you do when you bring the Terk into the picture. The Terk is great for use with radios that don't allow for peaking the antenna on the tuned frequency (older radios used to do that automatically), but with something like the EP-Pro or CCR2E/3 it's just duplicating capability already built into the radio. You'd need a much larger air core antenna to gather significantly more signal than the EP-Pro does already.Setting the TERK to the right of the radio so I could pass my hand through the loop to make changes on the radio worked extremely well. Changing the radio frequency and then changing the knob on the TERK about the same amount really made a big difference and it easy to fine tune weak stations.
I love this kind of stuffThe two things that make a great AM radio are the antenna and the receivers selectivity. If you have a radio with good selectivity the antenna can be an easy upgrade. I just finished making a 16" long ferrite rod antenna and I'm blown away by its performance. I built it from specs here and also use a preamp with about 15dB gain and good high signal handling capability. Besides using a huge ferrite rod, making the ability to tilt is also very important to get the best null to see what may be hiding under a strong local station. This thing is sharply resonant and covers from below and above the AM broadcast band.
Video on how to build antenna and recommended parts:
Preamp I use, modified for lower freq range: 2x J310 Push-Pull Low-noise HF pre-Amplifier (30 KHZ - 30 MHZ) Built & Tested
Picture of my working antenna, subject to a few more revisions:
The real test of AM performance will be how well the radio receives a weak distant signal (especially when adjacent to a strong local station) during daytime when the signals are steady groundwave.
You can get a lazy-susan turntable, the swiveling part you'd use to make a full lazy-susan, at Home Depot for less than $5. That's what I use. Works great. I put a piece of that rubbery shelf lining under it so it doesn't slide on the table and another on top so the radio won't shift. It makes nulling a signal with accuracy so much easier. It turns easily but holds position well if the table is fairly level.Try putting your EP on a cake decorating turntable and rotate it to peak desired signals and null unwanted signals.
Such a turntable is cheaper and more compact than a lazy susan. Probably can find one at a kitchen/bath or craft type store...
ask a YL, they'll know.
From your lips to the multitude's ears. While it may be fun to hear that station 1,000 miles away at night, it says virtually nothing about the abilities of the radio or the operator. My $12 used Sony pocket radio can get stations from 1000 miles at night. Day time I'd be lucky to get 100 miles with that thing unaided by external antenna.The real test of AM performance will be how well the radio receives a weak distant signal (especially when adjacent to a strong local station) during daytime when the signals are steady groundwave.
Yes! Phenomenal list. (I just wish it included Canadian stations).FYI - If you google "Mesa Mike's List of USA AM Band Radio Stations" you can get a FCC list of all AM radio stations (4653 of them) along with the DISTANCE from your location and their BEARING from your location. You just enter your lat/lon coordinates and then download the delimited text file. I had to replace all the "|' delimiters with "," delimiters to get excel to read the delimited file correctly. Then I filtered the data using excel to weed out only those stations within 100 miles (or 250, or 500, etc) to make the list more manageable. This info helps identify the potential source of MW signals and also helps positioning the radio based on bearing to the source antenna.
...and selectivity (the ability to reject strong off-frequency signals)--especially in bigger markets where there's a broadcaster on almost every channel.
One of the radios I own had a bit of a reputation for images and overload from local signals. I was curious how bad it could get so I found the transmitter site for the local 50kW station and drove there. When I was 100 yards from the antenna it was nothing but that station all up and down the dial. When I got a mile away it had dropped off to only affecting two adjacents on either side. At two miles it was just the adjacents. By three miles there was some impact on the adjacents but that could be addressed by tuning away a bit.
That 60 year old Juliette probably cost many times what the Sony ICF-P26 goes for in equivalent time value currency. That it's still working today is a testament to the quality and care taken in its manufacture. One of the big weaknesses with small radios like that is the antenna. Ferrite rods are not widely known for their consistency, requiring tuning of each individual unit if you want the best performance. Since the whole idea of transistors was a big new thing 60 years ago, they probably did all they could to ensure each unit was properly tuned before it left the factory. Nobody's doing that today on a $20 retail radio. How could they? The manufacturer is probably selling them for less than $10 and making very little at that price. If you're adventurous you can take the radio apart, pick off the wax holding the coil to the ferrite rod, and then move the coil to peak it, waxing it back in place when you're done. If you want peak performance out of a cheap pocket radio, you're going to have to do that to virtually all of them.
I wouldn't hold out hope on the ICF-S10mk2. It was the worst pocket radio I've ever bought.
The best MW pocket radio I've used is the Sony SRF-T615. Great sensitivity combined with excellent nulling capability. Not terribly selective so this can be a problem if you live in an area with a lot of strong local signals. It also isn't available anymore and cost a whole lot more than the ICF-P26 you didn't like.
It's been my experience that radios with a low threshold to ownership are purchased in great numbers by people who are not experienced in DXing or in objectively judging the characteristics of the radio. Someone raving about the reception of a 50kW flamethrower at midnight from 500 miles away is a good example. Such reviews are of questionable value.As for the Sony ICF-S10mk2 I have read good reviews on it and in fact many comment it's better than the ICF-P26 in terms of performance for a small portable radio. Obviously atmospheric conditions when listening play the biggest factor when trying to DX with any radio.
