Porting op25
wgbecks
NE Wisconsin
I think you are asking if you can connect a Bluetooth audio device to the RPi to hear your op25 audio. If this is the question then the answer is yes you can. It's done not with op25 but in the configuration of your Linux sound devices.
Watton925
The problem is that I get audio thru hdmi but when connected to Bluetooth speaker nothing
Watton925
So that’s why I’m thinking it needs ported to said Bluetooth speaker
boatbod
Talbot Co, MD
You can either redirect your RPi to output using raspi-config tool or tell op25 to use a different audio device using the "-O <alsa device name>" command line parameter.
Watton925
I’m trying to get op25 audio to come thru on Bluetooth with no luck
a417
can you hear it locally on the computer you are trying from?
Watton925
I believe I need to add the -O parameter but not sure what device name to use to output it to Bluetooth
