BOEC simulcast Reception
You said you were living in the Orchards area, and I can tell you that you are (in reference to Portland) located behind a rather large hill (escarpment, actually as it extends from Grand Ave. downtown Vanc. to Camas) and the ridgeline is approx along Mill Plain.
I am a bit confused about your antenna. Have you attached a Rat Shack 800 MHz duck to the back of the radio? I haven't heard of any other external outside antennas other than the ground plane and discone. I believe either would be unity gain on any freq. Therefore I suspect that most of these guys are on the right track in saying that only with an antenna, as high as you can mount it will your reception improve. I am mistified by the gentleman living along Burton however who had trouble getting BOEC from Cascade MS as it is on 18th up on the hill from where he lives (albeit on the back/down side of the grade of the hill).
I live on 7th St., near 162nd Ave, and get really fuzzy reception of CRESA in my car on a Uniden 996XT. I have always suspected it was (as Jeremy indicated) a decensing of the RX because of my proximity of both Prune Hill and Livingston. Never thought of a NEXTEL site. Even I have problems (at certain times) getting BOEC, but usually can on even a handheld with a very short 800 MHz duck on it. But again, I'm up on the hill. In my car I can get VHF sites 50 miles away full quieting, but have issues with 800, especially "picket fencing". Naturally, this area is surrounded by cell sites and who knows any more which ones are NEXTEL. Their antennas used to be easier to spot.
I think geography is playing havoc with your reception and even a ground plane would improve if up high. I have built several using mobile 800 MHz whips and NMO ground plane kits that you can usually find floating around. Heck I built one around leftover Antenna Specialist parts and a solid aluminum disk using a 3 db mobile whip. Worked great! If you can get a yagi, they are the best, I just haven't found one inexpensive enough at a ham show. Grab one of those and get it up high, experiment with sites. They are on the right track with the antenna, but be aware of your location in relation to the topography.
