POTUS Queens/East Hampton NY today
I know that. Wondering if he got 757 from the screenshot of Sam46 which was circling for a long time (never landed up here that I saw) while potus was route to his location via another aircraft.
Last night 09-0015 was SAM46, the backup, while 09-0018 was AF1 to Hagerstown, both are the B752 (C32) along with 09-0016 and 09-0018/19-0018 (depending where you look).
The VC-25 (747) was 92-9000 that flew from RDU-JFK then returned to ADW empty.
Rudy3145
New York
Biden was in NYC for fundraising events, and he stayed overnight Fri into Sat. Saturday, Marine 1 took him from Manhattan to JFK. Then JFK to Gabreski via AF1 (the 757). Then Marine 1 from Gabreski to East Hamp Airport. He motorcaded to 2 fundraising events, then back to East Hamp - Marine 1 back to Gabreski and then flew out to NJ for additional events.
That tracker map above was 100% not POTUS.
The US Air Force is not going to let civilians follow POTUS in the air.
Do they put false info out there on purpose? Possibly. But the info I stated above is 100% accurate about the events on Fri & Sat.
And FYI - AF1, POTUS would never circle like that. He flies direct, unobstructed. If there was a weather issue or an emergency, he'd re-route or return immediately. They'd never circle like that in a holding pattern.
richee2000
Monitoring NYC from Sea Bright NJ, East Hanover NJ
I have tracked the actual AF1 numerous times on ADSB, with a direct visual view of AF1 landing at Morristown Airport when Trump was POTUS, with live media coverage confirming it was, in fact AF1 with POTUS aboard. Tracked AF1 with Biden coming in over the Jersey Shore coast, landing at JFK, again with direct visual of the aircraft, and confirmation on Live news media when POTUS got off the aircraft
Rudy3145
New York
Well I can tell you, that tracker posted above was 100% not POTUS.
It seems, reading this thread, that there has been a misunderstanding. No one ever said (that I saw) that the image in Post #9 was AF1, as a matter of fact it says that was SAM46 09-0015, which is the backup and routinely circles prior to AF1 departure. Post #7 was 09-0018 or 19-0018 depending where you look (there is confusion over the actual tail number with tracking sites) and was AF1 after departing NYC, it replaced 92-9000 due to the size of the runways it was going to, including Hagerstown which was the final destination for POTUS.
Either way, I really don't see why this has turned into such an issue with everyone, the event is over and it really doesn't matter.
AF1 can be tracked the majority of the time on ADSB Exchange, Airplanes.Live, and several other tracking services, though usually not on Flightaware and Flightradar24. Marine 1 usually can not be tracked. I track AF1 almost every time it flies, especially when I have credentials to photograph it as I had last Friday morning as it traveled from Dobbins ARB to RDU airport, where it arrived as expected based on our tracking of it.
