BC75XLT: Power On After Battery Swap Issue BC75XLT
air-scan
I have 2 sets of Duracell AA Ni-MH rechargable batteries I charge with the Duracell charger they came with. They charge fine..
The issue is intermittent. I think it's a battery seating method or I am I swapping them too fast? Batteries feel snug once placed into the battery compartment but then I try to power on the scanner it won't power on until I reseat the batteries. Looking at the battery contacts I don't see any corrosion.
Do I need to wait some time before inserting freshly charged batteries or are the battery contacts needed to be cleaned?
I use this scanner for it's nice aircraft band reception while eyeballing ADS-B.
wtp
Port Charlotte FL
check the negative part to make sure there is no loose plastic that has been pulled off a little.
that has happened to some of my cells.
