XTL/XTS5000 Power Test On XTL2500
A couple of questions:
- How long is the cable between your radio and the power meter?
- What kind of cable is it (Brand/model/type)?
- Are there any adapters used in the run between the antenna jack on the back of the radio and the power meter? If so, what kind and how many?
WRMZ361
Bronx New York
I cable is a 💩. But I am ready to buy the Wilson 400 cable. I got 100 ft of cheap coax cable, RG4
WRMZ361
Bronx New York
When I do the test, I plugged everything. The radio with the antenna etc. Because I want to read the SWR too.
WRMZ361
Bronx New York
Yes Sr. I think I buy the wrong meter.
If you are running 100 feet of RG-8 from the back of the radio to the watt meter, then there's your issue.
If that is what you are doing, I'm really surprised you are seeing 33 watts out of that setup.
You should be using a short (3 feet or so) high quality coaxial cable jumper with the correct connectors (no adapters) from the back of the radio to the watt meter, and from the watt meter to the 50Ω load. You need to figure in that there will be some loss in those test cables. You also need to figure in that the watt meter won't be 100% accurate.
I'd stop and set your power levels back down to 45 or 50, and not mess with them. You run the risk of letting the magic smoke out of your radio if you are trying to squeeze 50 watts out the end of 100 feet of RG-8X.
I don't think you did. I think what you are seeing is probably accurate based on your setup. Buying a more expensive meter and expecting it to be accurate with that setup is just going to be a waste of money.
