PPS Bluetooth Enable?
shadow925
San Diego, CA
I'm having no luck finding a setting in the PPS to enable bluetooth on my G4. Each time I program the radio I have to go into the menu to enable bluetooth. Not a huge deal but I usually forget and find myself wondering why my earbuds won't connect. Is there such a setting?
Thanks.
RBMTS
Push the "F.Sts" soft button under the display or push the larger right hand lower button (the the circles on it). That is where you can turn BT both on and off and ultimately try to pair a device.
shadow925
San Diego, CA
Thanks for the response. I do know how to turn it on from the unit's menu. I was just wondering if there's a way to turn it on through PPS so it will be on whenever I program the radio instead of having to use the menu each time.
