I have a Pro 106 and 197 that I used to use all the time, but they have stopped receiving BCSO and most other entities I want to listen to. I get the conventional frequencies OK. I am pretty sure it is something I don't have correctly configured, but I can't figure it out. I have a good cable, ARC 500 software and a lot of frustration! Does anyone have a Brazoria County file? I am going to attach my current file. Any and all suggestions are welcome. Not a new scanner user, and I thought I had a pretty good understanding of how to program these guy, but I am being proven wrong! I have three towers equidistant from me, Angleton, Reed Road, and Friendswood. I am located in Manvel, TX which is in the North end of Brazoria County.
The Reed Road site is a "fill in" site. It carries radio traffic from agencies that may be away from their primary site.
The Friendswood site is in Galveston County, and might not carry all of your county's talkgroups. (There were comments in a thread, about a year ago, that Brazoria County SO was being carried on Friendswood, at that time. But see the note below on Phase II.)
The site you have entered as "HOS IC" is Houston Public Safety-Alvin. That site would only carry P25 Phase II traffic, which your scanner cannot decode. That is the case for all the "Houston Public Safety sites"; they will carry Phase II traffic, not Phase I. Those sites have a
3 in the RF S S column in the sites listing. The Alvin site is labeled as
3 (3), with
014 in the site column.
The site map for the Brazoria County Simulcast is here:
The most complete database of radio communications data
www.radioreference.com
In Manvel, you are relatively close to the northernmost tower, but the other two are farther away, and "behind" the closest one to you. That could be an issue.
There are notes over on HoustonScan, on groups.io, that Brazoria County moved to TDMA several months ago. TDMA, P25 Phase II, cannot be decoded on your scanner. In the database, for
TxWARN, I see that Brazoria County S.O. Dispatch 1 is tagged as Phase II (the
T in the mode column). You might have your thread moved to the Texas forum, and ask there if the rest of Brazoria's TGID have also moved to TDMA, but not yet updated in the database. To do that, do
not create a new thread. Instead, click on the Report in the lower left corner of one of your posts, and request that a moderator move your thread to the state forum. Someone in the area would be more likely to see it there.
I should add that most of the Manvel talkgroups are tagged as Phase II (the
T in the mode column again), and is already noted, your Pro-106 & Pro-197 cannot handle Phase II.
