pro-106 need help
balou
ontario
can i use win 96 for the 106
also
i want to put a few control chanels by hand ..im lost
any help would be great...
i have a few 2096 and 96 wich are easy but the 106 is making me scratch my head
balou
ontario
ok i got to how to program it..but my steps are off
if i put 142 245 it gives me 142 250
kb8rvp
Michigan
One nice thing you can do also with the psredit software is connect your Pro-96 and import the programming from it into the software and then make any changes you wish to make and then connect your Pro-106 and program it.
Good luck,
Mike
wyomingmedic
There is an extremely obscure reference in the manual about how to have 5khz step size on 136 to 174 mhz.
I had this problem as well and once I found the magic button, I was set. I then wrote GRE and asked why one Earth would they design a scanner to NOT have 5khz step size right out of the box.
Needless to say, I did not get a very convincing response
WM
So Far Away....
theres a option in the gen-settings tab (WIN500)under the FLEXSTEP..
i believe this is the enabler for the 5k step setting...
i keep mine enabled just to avoid this issue when hand tuning a freq..
ive noticed no determent-maybe a slower scanning speed,but thats minimal..
again,hand programming is nifty,,but personally,,the software
is just,,soooo,,,,21st century...
balou
ontario
thanks guys
i have arc 500
the guy i got the scanner from gave me the keys
not really wanting to buy another software if i got 1
if i could only change the steps i would be set ..just cant figure it out
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
thanks guys
i have arc 500
Global Settings Misc tab for 5KHz setting then select Expert tab for Flexstep setting.
balou
ontario
thanks fmon very appreciated
found it but im still lost
anyone have a opp zone 3 file i could have
balou
ontario
ok i subscribed again to rr
to get the downloads..but i still cant do it lol
not sure how it works
in arc 500 i go to internet the select all i need then import
the download to scanner ..all i get is nothing enabled
fmon
Eclipse, Virginia
Set as in image. Then click ScanList tab for list selection. Save and load to scanner then press list number on scanner to enable
Hopefully you set previous flexstep and 5 KHz settings.
balou
ontario
thanks again
more questions\you say save as image
how do i do that
i got to that screen the pic u posted
i click cochrane instead of sudbury
trunk sys
bell fleet
then it gives me 2 screen one with sites and the other with tg
do i click them all
after that just import
after this im lost
my 96'S ARE SO SIMPLE lol
fmon
Eclipse, Virginia
thanks again
more questions\you say save as image how do i do that After you select sites and TG's
trunk sys Cochran and trunk required for OOP Zone 3 to ungray for selection
bell fleet
do i click them all Select only sites within range and TG's for those sites
after that just import Yes
after this im lost After Save and sending to scanner, press the scanlist number on scanner to Enable.
This scanner will be simple as you use it.
balou
ontario
thanks fmon
i got it going for now..
its very appreciated
send me a quick pm ive got a couple questions for you
thanks again
