Pro 106 settings
Trying to set my settings on my 106 for the Conventional Scanning. Can not find this setting in the
Expert Settings . I went to the GLOB setting & went in to the individual Conventional frequency channel settings, still no luck. what am I doing wrong , any help ? thanks for the time, jbxfire
Conventional Scanning :
Setting the squelch properly is the easiest and quickest way to receive channels better.
Set the SQ Wait 1 (in the 'Expert Settings' menu) down to 7 or 5.
trap5858
Doylestown PA & Milton DE
Do you have your objects (frequencies) assigned to a scan list? If not, the radio does not know to listen to them. Are you programming by hand or with software?
Yes, I have them assigned to a scan list. And I do all my programing manual never have used a software.
YES , every thing is working like it is should , but cant get the SQ WAIT 1 to work, it is simply not there.
fxdscon
¯\_(ツ)_/¯
Press prog --> func --> glob
2nd line in expert settngs
FXDSCON Sir, Thank you very much. I found what I was looking for. The info I found in easier to read
pro106 was misleading to say the least. But thank you again Sir .
fxdscon
¯\_(ツ)_/¯
Glad you got it....
Not sure you were looking in the correct area in the "Easier to Read" site.
It's in the index under "Expert Settings Menu".
The link below takes you to that area, showing the same key press sequence (in red typeface) to reach those settings as I posted above.
There is also a good description of what all those settings do.
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
