pro 106
rdrake
Columbus, Indiana
just got this thing had programmed at the shack
it pick up the county fire, sheriff but it's not picking up local city police
all the frequency are in the scanner
thanks
Robert
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Your first mistake was letting anyone at the Shack do the programming...be that as it may...it would help if we knew WHAT county fire/sheriff and so on you're talking about. The devil is in the details!
Go up to the left, top blue toolbar under the site title and float your mouse over Database. Use the pulldowns to grab what system or area you're having problems with. C'mon back with the URL.
It's going to be tough to nail this down unless we have some idea of the programming that's already been done...best regards...Mike
Macomb, Michigan
thanks
Robert
Let us know what county/state/city you are listening too. That way we can help you on here.
Welcome to Radio Reference. You will find a lot of knowledge on here. The Pro 106 is a great scanner but can be intimidating if programmed by hand.
But there are few of us like my self who programs ares by hand.
shadcall
Ormond Beach, FL
I dont' think RS uses RR for programming scanners. I think I read somewhere that they were using Scanlite, but most of them quit programming scanners.
You might be able to put in the local PD freuquencies manually. I really don't know since your location isn't known.
Shadcall
Pro 106 Pro 163 Pro 164 Pro 62 Pro 2027
Antennacraft ST2
DX-390
jaspence
Michigan
RS scanners
The best way to avoid all RS assistance is to get one of the good Pro 106 software programs. They are easy to use and will save hours if you are punching in the data. The level of help varies greatly from store to store.
reconrider8
Eastern, NC
it all depends on your level of understanding about trunking in general really isnt to hard if you understand what you are programming and what you are setting up aka tower sites ect
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
i live in bartholomew county Indiana the city is columbus
i picking up county fire, city fire, county sheriff only thing i can't get is the columbus PD
here a link to the page
Bartholomew County, Indiana (IN) Scanner Frequencies and Radio Frequency Reference
Robert
Columbus Public Safety is rebanded Motorola II. Could be RS never programmed new controls nor set TTables.
Oslo, a few days ago you provided a user with an excellent pdf for rebanded systems including new control frequencies and TTables as I recall.
KC5EIB
Flower Mound, TX
I thought they all just use the RR database and download a local file for their respective area, and then load it into customers' scanners on request.
Radio Shack is moving away from programing scanners in the store. With the new software they are rolling out, we can not connect the USB programing to our systems, run the custom version of Scancat Lite and are not able to run the Iscan software either. I have built a basic load for my area that is in the display Pro-164,Pro163 and Pro-197 which I use to clone the scanners we sell.
Macomb, Michigan
That was for Ocean County New Jersey.
I didn't see trunking tables on there. Is that a UHF/VHF or just 800MHz rebanded? If it's just an 800MHz rebanded Analog I can make PDF file no problem.
If it needs trunking tables I need to know the whole tables lo hi channels, offset spacing,step etc...
rdrake
Columbus, Indiana
i have the program ARC 500 and tried to download the stuff off RR and it mess up or something and took everything off and won't pickup anything now
i do not understand this scanner at all i had a old pro-95 and i could enter frequency on it and it would work
but this one is kicking my but
Robert
Macomb, Michigan
Robert
I see that the Columbus Police,Fire,EMS and Sheriff are also on the Indianda Project Hossier SAFE-T
A40B015Columbus (Bartholomew)866.27500 866.38750 866.62500 866.88750a 867.33750 867.43750 867.93750 868.43750c
Indiana Project Hoosier SAFE-T Trunking System, Statewide, Multi-State - Scanner Frequencies
You should have no problem using your ARC 500 to program your Pro 106 using The link that says Columbus (Bartholomew)
Here some links that may help you ARC500 User Guide - The RadioReference Wiki
- Resources
I am still going to make a PDF file for Columbus Police for their System and one for the Bartholomew County on the Indiana Project Hoosier SAFE-T System.
Gives me something to do and helps others sometimes as a guide. Maybe I should become a technical writer using lamens terms.
